the photo is of the rear end, will any ford drive shaft bolt to this rearend if it has the round type of ujoint housing.
also must I find a drive shaft from a 5 speed stick, or will automatic interchange. I know I gotta shorten it.
tonite I routed the bottom hoses, discovered I have a 3:26 rearend ratio in this. that should be a good road gear shouldn't it.
also look at my upper radiator hose routing is this a good place for the filler neck.
I now have 465 hours left to finish and 2800 left in the budget. and just over 18 weeks till autorama.
I did not want to bore you so i only pasted here my new flickr page, I posted more pics of the build, and some shots of my barn.
http://www.flickr.com/photos/belair567/
