Thread: Rear End Noise
Old 09-17-2009, 10:39 AM
blykins blykins is offline
Grumbling or roaring is usually the sign of a bearing or a universal joint.
If not IRS, then I would start by looking at the outboard axle bearing. You can pull the axle then spin the bearing by hand and see if it feels rough.
A differential bearing would probably make noise at all times and it would be more prominent at higher speeds.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
