Old 12-02-2001, 11:25 PM
Sonny Sonny is offline
Default fit up
a quick answer is yes it will fit, but i would advise to go the factory five approach and use aluminum broke sheeting with the rubber sealing, along with the welding if 1x1x.065 ms tubing/1/8x1 ms flats as support frame for the body and drop trying to go the method the body mfg uses. just cut out the excess fiberglass.
SonnyB
