Old 09-18-2009, 09:19 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Really, there is nothing to see. All you see is where the latches are in the door where the striker enters to lock the door. The electric part is hidden inside the door. It is a one piece mechanism that attaches to the door with three screws, Rocky provides allen head screws with the kit. Look at the web site and use the product number to go to the correct page. It is pictured there. It's to late for me to include a photo of the mechanism as they are wired into the doors now. Tested them for the first time this morning with the remote an they both unlocked.
You have to remember that a ground wire has to be run to the mechanism as they were designed to be in a metal door that would be grounded. Also, when wiring the system the power line must be HOT all the time. Wire it to the hot side of your master cut off. The kit comes with an interior master rocker switch to open the doors electrically from inside the car. The mechanism comes with wire cables etc. to run to a pull type manual door opening handle inside the car.
bkozlow
