Old 09-20-2009, 03:24 PM
garry viohl garry viohl is offline
I will save you a lot of work. I had the milodon gaskets and they leaked in the rear, I tried two times with them. Now I am using Felpro rubber coated gaskets, no leaks. Good luck!
http://www.summitracing.com/parts/FPP-1817/
Did you line bore your mains? If so, your rear main cap will sit lower than the oil pan rail. Use some peratex #2 form a gasket just on the rear main cap.
