09-20-2009, 07:15 PM
See comments within:
Originally Posted by dcdoug
So I think a couple of studs makes sense and then I will probably stay with bolts for the rest. Loctite on the studs? Is it best to use two on either side to locate the pan?
Yes Locktite, yes one per side. Serrated head bolts from Mr. Gasket. Grade 8's and split washers a distant second choice.
And I guess for the gasket, the Milodon cork and black RTV seems like the option to try?
NO! not cork-Milodon #40405! It's composite. No Locktite RTV's- Ford Motorsport gray for diesel apps. $23 per tube.
One last question - is this going to be a PITA if the car is only up on jack stands and not a lift? Doesn't seem like it will, but then I'm the rookie, so comments are welcome.
Yes it's a PITA-like everything important you'll do on the car.
Chas.
