Old 09-22-2009, 07:17 AM
SPORTSTWE SPORTSTWE is offline
Default Engine build sheet
Ok guys.....here is the engine build sheet.......let me know your thoughts.....keep in mind that the car has 65 miles on it and is equipped with a T5 trans
* Horsepower: 400 hp
* Torque: 390 ft/lbs
* Block: Early Heavy Casting Block 1969-
0 1974 Fully Machined
* Crankshaft: Early 351 28oz
* Stroke: 3.500"
* Connecting Rods: Original 351 with ARP
0 Bolts
* Pistons: Forged Flat-Top
* Timing Chain: Comp Cams Double Roller
* Camshaft: Isky Hydraulic Flat Tappet
* Lifters: Isky Hydraulic
* Cylinder Heads: Edelbrock Aluminum
* Valves: Stainless 2.02/1.6
* Rocker Arms: Comp Cams 1.6 Roller
* Intake: Weiand Dual Plane
* Waterpump: Aluminum Driver or Passenger * Side Inlet
* Carburetor: Holley 780 Shiney Finish
* Valve Covers: Chrome Ford
* Oil Pump: Melling High Volume
* Oil Pan: Ford Racing Replacement
* Balancer: Ford Racing 28oz
* Ignition: Accel Electronic Distributor, Accel * Spiral Core Wires (Your Choice of Color)
* Gaskets: Felpro
* Fasteners: Stainless
* Compression: 10.5
* Fuel: Premium Unleaded Only
