Old 09-22-2009, 05:47 PM
Argess Argess is offline
MIne has been "wandering" for the past couple years. But as it was fine for years before that, I'm sure the problem is inside the tach. For the record, I did try a tach adapter, and I htought it seemed fine for a bit, but then back to the normal "wandering".
I strongly suspect a bad solder connection or leaky capacitor inside the tach, however the tach doesn't come apart as the front bezel is swaged over the case.
I havn't bought a new one as the pics I've seen on line don't seem to match the old unit (cosmetically,, ie.e the face and needle).
So, I am thinking of taking the tach,, cutting the case around the middle, repairing the circuitry, and then fabricating a band to hold the case back together. Probably an internal band with countersunk screws through the case so the unit will slide into the dash easily.
And with the $100 I save, I can.........hmmm, what can a person do to his Cobra for $100?.........
