The lip is the piece of thin sheet stock that is welded to the upper section of the cowl bar on the cockpit side. The lip of the dash rests on top of that lip when the dash is installed.
If you plan on using a wooden dash or a metal one that is of flat sheet stock that would attach to the cowl bar using screws, then you would not need the lip on the cowl bar.
Terry
Reason: spelling
