Steve, Okie, Roscoe
Thanks for the input. As you all suggested, I'll cut away the leather first. Then probably use the cutting tool I'm most comfortable with.
Ikestaa (You're an Eskimo perhaps?
For my ignition setup, I think it's just a matter of running a wire from the ACC terminal on the ignition switch to one starter button terminal, and a wire from the other starter button terminal back to the ST terminal on the starter switch. With the ignition switch in the on position, you can then start the car either by hitting the starter button or by turning the key all the way on the ignition switch. Key words here - "I think." I've come close to electrocution just doing simple household wiring tasks, so I can't promise anything.
