Old 09-23-2009, 08:34 PM
sambo's Avatar
sambo sambo is offline
Thanks Stiffy. Same gauges/senders as mine and I have the same pan, so do you know where the oil pressure sender is mounted in the pan? You mentioned adapters but did you mean senders? The water and oil ones are very similar except for a white or yellow bead around the top (oil is the yellow one).
