Old 09-28-2009, 09:34 AM
Wayne Presley's Avatar
Wayne Presley Wayne Presley is offline
Cobra Make, Engine: FFR 302 stack injected
Send a message via AIM to Wayne Presley
Where did you get the webers? The IDA's come with 2 transfer ports to transition from the idle circuit to the mains. Redline drills a third hole to supply just a bit more fuel to help them run smoother. I really need the cam specs to tell you if it will work with the Webers. It will run very well above 3000 rpm but around town manners could be poor or worse.
Wayne Presley
www.verycoolparts.com
