  #87 (permalink)
Old 10-01-2009, 03:19 PM
tcrist tcrist is offline
Originally Posted by rustyBob View Post
Building a better mouse trap...............is there a great demand for those hinges?????
If they work as intended and you can keep the costs down, I could see a lot of CR owners that might want to convert. Especially if they are designed to be a complete R&R with no major mods the the framework. I.E. no removal of anything except to remove the door, swap out the hinges and re install the doors. It would be up to the individual to remove the "WEB" where the front of the door seals in the door frame, if they want to.
This will swing the door further away from the door jam. If you remove the "WEB" then it would make it easier to swing your legs in and out. The wife/girlfriend would appreciate it.
JMO, Terry
