Old 10-04-2009, 05:26 AM
Krewton Krewton is offline
Cobra Make, Engine: Classic Roadster II
The engine is a Teskid block 6 bolt main (aluminum bock) It has been bored .030, fitted with new-h-beam rods arp rod bolts, sealed power pistons with coated skirts, 5cc dish should have 9.5 compression. The crank is standard on the rod and mains. The heads are from a 2001 mustang cobra, they have been reworked (valve job and milled for true) springs checked etc. This is a 4.6L 281. Stock this engine is fuel injected, but I'm having trouble finding a stock 03/04 Cobra aluminum intake, injectors and plentum. I certainly want the performance, but would like to keep a nice look. I've seen many setups on regular mustangs and other 4.6L engines, but the intake is plastic and it the big throttle body style.
