  #195 (permalink)
Old 10-04-2009, 05:24 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Fred,
Your work is impeccable but I will tell you-that's the exact location my long torque wrench with small extension and 5/8th socket goes (to rotate the balancer bolt) when I adjust valves or any time I have to rotate the motor by hand.
Can you see the marks on the balancer to set timing? I hope you don't have conflicts.
Chas,
The thermostat (and all of the lines) are in front of the cross brace in the car. The balancer, timing tab, and the area you need to get at to turn the balancer is behind the cross brace so there is no interference. On a happy note, I have a hydraualic roller camshaft in my car so I don't adjust valves very much .
- Fred
