Old 10-05-2009, 08:29 AM
davecobra davecobra is offline
Cobra Make, Engine: #010 SC motorcars 428PI TKO600
Default ignition switch engages starter after engine is running???
I just got my cobra running but I have a wierd problem, when starting the car, sometimes the starter will engage again after I return the key to the run position, sometimes just turning the key to the run position it will engage the starter, I have already replaced the switch with another new one, it seem to be okay for a day or two and then it starts to act up again, I have check the wiring for shorts ,it is a new wiring harness and very simple system.
I have a LA Exotic with a 428 and C6. Any suggestion would be appreciated.
Thank you
David
