Old 10-05-2009, 01:58 PM
Rwillia4's Avatar
Rwillia4 Rwillia4 is offline
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Originally Posted by Jerry Clayton View Post
I only briefly breezed thru these postings---as Scottj said get pressure guage--
If the pressure is equal---you need to check to see if the calipers are exactly the same area pistons
another biggie I saw in your post was the switch from dot 5 to dot 4 fluid--with that you have ruined all the seals and o rings in your system---
Please explain? I know the two aren't compatible so I flushed the system (pushed a lot of DOT 4 through and then did it again a few days later). I've never seen documentation where if you have used one you can never switch to another.
On a similar note it did the same thing with the DOT 5
