Old 10-05-2009, 05:36 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Check the sizes of the rotors, calipers and the pressure---If---the rotors are the same(size, thickness, material) the calipers are the same( size, not type or brand) and the pressure is equal----the brakes should stop the same-----
bounce the corners of the car to see if the left front is stiffer than the right, and also if the right rear is stiffer than the left ---
The dot 4 fluid will not flush out dot 5 even if you pumped 50 gallons thru it----
