Originally Posted by jhwalker
Good job on upgrading. I'd find a way to get that last bolt in.
Hello, James!
Reaming one of the bracket holes to get all four in will be better than just having three. Some would argue that just getting two in with the new bracket is better than the old set-up. RT does a good job of machining these, but you may have very slight adjustments to make from chassis to chassis. I had to ream one hole on one side and two on the other (all on the bracket...impossible to do on the car portion without special angle drills) to get mine snug. And they are definitely in there good.
I still have the old brackets if anyone is in dire need of a door stop.
-Dean #747
