  #53 (permalink)
Old 10-06-2009, 10:18 AM
patrickt patrickt is offline
Originally Posted by dcdoug View Post
Does anyone know if I can get the pan on with the windage tray on a CSX car? It was a tight fit getting the pan off and clearing the rods since the frame cross member doesn't allow you to drop the pan much.
I don't know the answer to your question. But I will tell you if that was my car and there wasn't enough room then I would loosen the motor mounts and lift the engine up a smidgen in order to do it. This is not as big a deal as it sounds; the hardest part of doing that is borrowing a lift for the day, but the CACC has a couple that you can check out of the "library" any time you want.
