  #78 (permalink)
Old 10-07-2009, 11:52 AM
patrickt patrickt is offline
Originally Posted by dcdoug View Post
OK, I re-watched the TimeSert video clip. Does the seat cutter that makes the countersink in the lip ensure that the tap goes in plumb or only makes it more likely that it will go in plumb. Chas has me paranoid about getting it plumb now and I think that is an issue when you are doing it on your back.....
If the hole that you drill is really off center, it won't fix that. But if it is just a little bit off it should compensate for that a bit because the seat lip cutter has a depth-stop on it. What that does is make the doo-hickey sit flush at the top which will also, presumably, make it be in straight. The hole doesn't have to be in absolutely 100% perfect, but you do want the new hole to be flush with the block and that's where the lip reaming effect comes in. Here, I found the instructions for you on the TimeSert. It's pretty easy to use, that is if you have the room to maneuver under there. http://issuu.com/wurthuk/docs/time-sert
