Old 10-08-2009, 09:51 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Balancer - Ring Slippage
Argess,
For the rest of us folks here a little more detail in the failure would be helpful.
Was this a tired 30 or 40 + year old damper or was this some aftermarket relatively new part ? I am tring to understand if its a part quality issue (so others can get a heads up) , or a dry-rotted, aged, shrunken dampening material in the balancer ? In other words do you have an idea as to the root cause ? The reference marking idea is good and will help others monitor the damper if slippage begins to happen. Sorry you had the detonation failure, that just plain sucks.
Bill
"...some assembly required, ages 8 and up...... well that took longer than expected......
