  #203 (permalink)
Old 10-09-2009, 04:54 PM
patrickt patrickt is offline
Originally Posted by Bobcat View Post
Do you know what is inside the Canton unit that could allow the oil to heat up to the 170 degree range while idling ? Sounds like there is some type of orifice that they force the oil to go through . GPM through an orifice equals pressure drop equals heat generation ... and in this case , it sounds like a good thing ( here I`m being an anal engineer again).
I don't think that's right. The instruction sheet says that it simply bypasses the oil cooler until the oil reaches 215 degrees. I don't believe it increases the temperature by reducing the volume passage, increasing pressure through an orifice, etc. I can see problems if it tried to do that. http://www.cantonracingproducts.com/...PDF/22-480.pdf
