vector1 Mark sorry you didn't get more track time in. That is a nasty fast looking cobra. I am gald you found the other problem in the car. When you have a little time, you need to goggle vacuum pumps and read the articles by CZ about max pressure and having pressure pin oiling to the pistons. For your motor a 8-12 Hg is max and min,
P.s with all the rain we could have fixed it there
. Gald you came, looking for a better R&G next year. You did miss the fun in the barrel race.
First place was Dean L. with the most donuts on the track in Clois car
Second place was Sam W for how many 360's around the first barrel.
Third place using the unknown driver rule was, Jay and Dean looking to run from the box and someone sliding through the box.
Fourth Place was the Bill B. with the too much power just off idle
Last and craziest was Dave from Fasttimes for the 4 coughing burnouts to remove the water and heat the tires. Also thank him for the great lunch at his wonderful shop. Hope you have the problems fixed for next year. Rick L. Ps we had a walmark and could have pulled the drive train there.
New rule, no more going home unless the motor is BLOWN.
Oil leaks will be fixed and racing will continue
