Originally Posted by ERA Chas
-and the fact that you're not passing 40 to 100+MPH, ambient temp wind over all the exposed parts of the system we discussed. Don't understand the last part of your sentence there Fred-are you saying what I just said?
I believe that the 'sheltered' position of the t'stat and it's lines may not provide the benefit you suspect while driving. As you saw, covering the cooler did next to nothing. You will still be passing fan and rad air over the t'stat, albeit warmer than ambient.
Testing will tell.
Chas,
Check out the post with the testing data. I am seeing a significant increase in
oil temperatures with the Canton unit on the car. I am seeing an increase in my
oil temperatures from 50 C to about 75 - 80 C in the cold weather here in New England and I no longer need to block the
oil cooler.
- Fred
