Old 10-11-2009, 08:46 PM
eschaider's Avatar
Originally Posted by Krewton View Post
Actually, the 03 Marauder and 01 Cobra are exactly the same. Here is a shot of it mounted on the engine. Still have to send the chip off for reprogramming. Then we can look at some of the chip upgrades.
http://picasaweb.google.com/levingsk...79401905795554
Still a ways away from having it running, but will keep you posted.
Krewton
Krewton,
You are correct about the 03 Marauder and 01 Cobra manifolds. They also match the 03/04 MACH I manifold but they do not match the 03/04 Cobra manifold.
The 03/04 Cobra manifold exclusively mounts a supercharger and does not look anything like the manifold you want. The manifold you see below is an 03/04 Cobra intake manifold. If that
is what you want, then you will need a supercharger to put on top of it. If the manifold you are looking for is the one in your last posting then you might have some additional luck by including MACH I intakes in your search.
Most of the time you can find good used ones for $300 - $400. If you want brand new, as in a take off, they are much harder to find and can go upwards of $600 or more depending on how proud of it the owner is.
Ed
