Originally Posted by Got the Bug
You're not talking about the cars with two roll bars that are covered with the protective insulation designed to prevent pipes from freezing?
Well then that excludes me.
I'll have you know that my roll bar padding is the Kirkey $2 stuff that's fatter on one side than the other. Perfect for bending around the hoop.
The pipe freezing stuff it way too expensive and not nearly as soft when you're tapping your noggin against it.
http://www.summitracing.com/parts/KIR-99001/
