  #21 (permalink)
Old 10-13-2009, 09:07 AM
Scufty Scufty is offline
Cobra Make, Engine: Butler Racing/427 side oiler
Originally Posted by Argess View Post
I'm amazed at the number of distributor drive gear roll-pins shearing.
As a note, I posted a "fix" for the dist gear pin shearing here:
Mallory Distributor Tip
How many of you removed the oil pan to get the bits of the shear pin out?......chuckle
How bout pulling your motor to remove bits of your distributor gear cause the oil pan cant be taken off without do to a crossmember (frame) Frickin pain in the hoop
