  #26 (permalink)
Old 10-13-2009, 04:30 PM
Argess Argess is offline
Originally Posted by Silverback51 View Post
If you shear a pin, the 3 pieces of the pin should still be in the gear and shaft.
No, I don't think it happens that way, although it can. If they were solid pins, it would more likely the pieces will stay with the gear and shaft, but these are split-pins: hollow, spring steel. And on a dist like a Mallory, which has a loose gear-to-shaft fit, the pin doesn't actually shear. It fatigues, then cracks, and when it finally breaks, the "springiness" can frequently drive a piece, or pieces into the engine. A press-fit gear/shaft may do a more traditional shear and the pieces may stay with the shaft.
When it happened to mine, the gear was devoid of pin parts, however the shaft still had a piece in it....naturally, as it can't get out.
