Old 10-13-2009, 04:50 PM
Argess Argess is offline
Originally Posted by PaulProe View Post
When you change a distributor or its drive gear, it is essential you set the proper end-play. If you don't it and the drive pin is subject to higher than design forces.
Going to a larger drive pin is just a mask for an improperly located drive gear. That is the reason they come to you un-drilled, with a pilot hole. If installed properly, all the forces of the gear and camshaft are absorbed by the boss in the block, not by the drive pin.
Here is a link to the Ford bulletin: Distributor gear installation
Paul
That's a different problem. Note that in the link you provided, it states "press the gear on the shaft". With a Mallory, it's loose. No pressing. That's a problem. I even thought of getting the shaft or gear knurled to help things, but just went with a pin upgrade. I am absolutely certain, in my case, there was plenty end-play clearance left after the dist was clamped down.
