Old 10-15-2009, 05:55 PM
patrickt patrickt is offline
Originally Posted by PeteF View Post
I did an oil change and grease job on 2041 last weekend. I could access all the grease fittings except the driveshaft. Any advice on how to get to them from underneath, or does the tunnel have to come off ? The car has 39,000 miles, so how important is it to grease the driveshaft u-joints.......how often do you guys do this? thanks
It's really important to grease them, and the front drive shaft u-joint can be a real bitc_ to get to. Here's a Spicer video I posted a couple of years ago showing you the proper method of purging the four posts. http://ujoint.kickme.to You should purge them at least every 10,000 miles or so. Since you can't get to it from beneath, I would first try removing the four screws that hold the shifter boot ring and see if you can get to it with a longer extension through that hole. If you can't do it that way, then your next option is to remove tha passenger seat and cut a small access panel under the carpet and through the tunnel. That would be pretty quick and easy. Your final option is to remove the tunnel.
EDIT -- What's blocking the rear drive shaft u-joint? That one is usually easier to get to, at least on my car -- FIAs must be different.
Last edited by patrickt; 10-15-2009 at 06:17 PM.. Reason: Added additional thought
