Actually quite easy,change the spray pattern to something not quite so aggresive,direct the spray over and away from known leaks.Windshield from the top down,same with the doors.The rear window with top on, again from the top down.You are not going to stop all of the water from finding it's way inside.In my case with no carpet on the floors it is much less of a hassle and worry.Do it enough and you will figure it out.
