Old 10-19-2009, 06:55 PM
patrickt patrickt is offline
Originally Posted by RET_COP View Post
... TDC is halfway between, do I have this right?.
thanks,
Yes. Just make sure you insert your piston stop to exactly the same depth both times (make a "12 o'clock" on it so you know you've put it in the same depth both times). Your TDC will be exactly mid point between your two marks from when the piston hit the stop each time.
