Originally Posted by slider701
Another option is to buy one of the Ford Racing "Aluminator" short blocks like the one below:
http://www.roushyatesparts.com/4_6L_...6009-a46sc.htm
For $4300 you get a brand new aluminum short block that you can bolt your heads, supercharger, and all other accessories on. This will shed about 80 lbs off the Terminator engine that has a cast iron block....which weighs around 800 lbs as a complete engine, which I believe is heavier than a FE cast iron engine. I'm sure most people would agree that taking 80 lbs off the front of a Cobra can be valuable.
I highly doubt a local shop can rebuild your engine for less than $2500 if it needs a crank and other parts associated with oil starvation. These engines didn't like being run lean and had a tendency to severely scuff pistons and damage bearings in the process.
As part of the development team for the 2003 Terminator program with Ford I can attest to this first hand, seeing this on many test and customer cars.
The issue with the engine was not severe as the crank and rods are in great shape. I have considered going with an aluminum bottom end... but was curious on the difference a properly balanced engine rebuild would quote out at.
I will agree that shedding weight up front would be good for these cars, but thought the weight of a terminator was more around 550-600lbs than 800lbs but cannot recall.
Thanks
