Old 10-20-2009, 11:14 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Heat Insulation, whats is your ride ?
Ok I am about to move into the build phase where I select a heat barrier for my chassis floors including the trans tunnel and firewall. Its all painted steel I will be bonding to. There is a bunch of insulation on the market. I want to know what works and what dosen't and the pros/cons you have found in your builds.
The Koolmat material seems to be good product but what else is there that works, comments or suggestions ?
Heat barrier is my first priority and sound deadening is my 2nd priority.
Thanks,
Bill
"...some assembly required, ages 8 and up...... well that took longer than expected......
