Old 10-21-2009, 06:30 AM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
Originally Posted by Rick Parker View Post
Gatorac:
When you Road Race with a live rear axle you must take preventative measures to keep the lubricant in the pumpkin. What happens is the oil gets forced into the axle tubes in sweeping turns and the bearings (and gears) run dry. The cure are special seals that are fit into the axle tubes to prevent the oil from being forced into the tubes by centrifical force. Circle Track racers know about this all to well.
This axle is set up like a circle track car. The seals are in the pumpkin and no oil is in the axle tubes. The wheel bearings are grease packed.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
