Originally Posted by RET_COP
I'm looking at the timing tab which is located at the 10 o clock position and its about 3/4 wide. Which side edge is usually the timing location, Top or Bottom. It probably covers at least 10*.
Lou
Even
I can't tell you via this forum where your timing tab should be.
But I can show you a pic of mine with the piece of metal tack welded to a pointer to be at exactly the right spot on my engine. Here it is -- I read the timing marks at the BOTTOM.
