I had the problem with exhaust popping on the right side everytime I shifted hard and sometimes when I started the motor. I found it was only the connector from header to exhaust pipe loose. I went thru everything ( carb, plugs, wires ) I had 2 loose bolts after fixing the problem no more pop
Life starts when the little needle goes past 6,500 rpm's
