DAN, if the problem just started, check all connections and cables.
If you have always had a problem ( like at Berea) check batt cable size. #2 ga is the minimum for trunk mounted battery. Bigger is always better in battery cables. For 2 years I had a hot start problem, great when cold but hot it was just like timing was advanced. Put a 2 ga instead of the 4 ga from solenoid to starter and it spins like like factory when hot. Also I used the old 4 ga cable for a dupe ground to the starter mounting bolt. Why toss it in the parts pile?
How is the switch from leaf to IRS coming along?
