10-23-2009, 07:52 PM
Doug, as a general rule, the front tires on our cars are going to have a couple of pounds more than the rear. One way you can get a feel for the best pressure is by using a pyrometer to measure the temps on the inside, middle, and outside of your tires. You then adjust the pressure so the middle temp is as close to the other two as possible.
