Spare Tire in a B and B
Has anyone put a spare tire in a B and B? I believe it can be done by using a Mustang donut tire. You cut a hole in the rear fiberglass panel enough for the tire to go through, and the trunk to close. The hole is glassed in to fit the contour of the tire. The tire would miss the rear axle by a couple of inches. Some brackets would have to be made from one side frame to the other to span the gas tank for the tire to be bolted to. The fuel line would have to be re-routed. I am not sure about the battery yet.
Opinions?
