Old 12-07-2001, 08:26 PM
Dan Stryffeler Dan Stryffeler is offline
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Thanks for all the advice guys!
I'll have the body off in the next couple weeks... will double check cable size and connections at that time and run new stuff if necessary (along with secondary ground wire to the starter). I have never checked to see if the cables got hot... it seems that just about everything under the hood does.
If all that is OK, will look at the higher performance starter and 'hotshot' adapter.
Thanks again,
Dan
