  #21 (permalink)
Old 11-01-2009, 03:12 PM
Double Venom's Avatar
Double Venom Double Venom is offline
jagrolet,
BINGO! Well thought out. If Don supplied the shocks and they are PRO's the part number will be stamped in the shock housing just above the lower shock mount. It should read -??- SM-600. Usually the spring is rated on the bottom of the spring, guessing 200 lbs +??. Somewhere around 11"s tall?
NOW, if you want a "fulldrop" SAFETY NET ( I have never seen the need for one, but you can use a cable wrapped around the axle tube with both ends of the cable attached to each other using a lead type 'compression' fitting. What you have done is simply made a full circle around the tube with the cables)!
Ramblin' again--Sorry!
DV
