Hi Tim,
I just dynoed a 408 that produced 491 hp & 515 ft lbs. It's a real workhouse with a mild custom grind hyd roller, Edelbrock heads, 10.4:1 comp ratio forged Eagle rotating asm & Edel Air Gap intake & Holley 750 dp. This engine produced 400 ft lbs below 3000 and peaked at 515 around 5000.... I use this custom grind camshaft on smaller engines with fantastic results. This would work fine in any car and run below 2000 rpm in 5th gear with np problems.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
