Old 11-03-2009, 08:02 AM
68 Fastback 68 Fastback is offline
Cobra Make, Engine: BDR, Stroked small block
Default Adjusting Hyd Valve lash
Question: On a fresh rebuild do you adjust the Hyd valves with them dry or with oil pressure? I would think it is with oil pressure. Note: I will build the oil pressure by priming the oil pump, not starting it.
Thanks
