11-03-2009, 08:23 AM
KY
Both.
Set them dry and then run them again when you get the engine hot and run it for a bit.
The procedure is the same for both dry and under pressure. Adjust so that there is zero lash, then crank about another 1/2 turn into it.
Note that some people think that you can't turn the pushrod when you've achieved zero lash. That's not true...you're looking for no axial movement at this point.
