Thread: O2 location
Old 12-08-2001, 04:45 PM
Webebob HI I have speed-pro F.I. system in my car. I have O2 sensor in both side pipes. The right side is for the computor, the left side is for the lean,rich meter so I can do quick checks when driving. I used a infared pyrometer for the hottest point at the collector in the exhaust and mounted the O2 sensor in those places. I have my header tubes rapped in thermo shield tubes so the heat stays in the exhaust. the system is real close between the meter and the laptop when checking the mixture. I am going to put a EGT meter in my car when I have the blower running as to not lean it out and damage the motor. Hope this helps. my sensor are wide band for supercharging but are not heated. My Alum. motor gets warm in about 2 minutes I have a 180 thermostat in it. It will run about 195 in the heat under hard driving and hold. good luck with it. Rick Lake
