Old 11-07-2009, 06:14 AM
Mooch's Avatar
Mooch Mooch is offline
Cobra Make, Engine: ERA 427 - #783
Turning towards a solid roller at this time, but haven't nailed it down yet. And no, I'm not doing a flat tappet...
I agree with your advise on anti-seizing the wing nuts - has been added. I had the "check the wing nuts" at every fill up since you are checking pressure at the same time and it takes half a sec so make sure your safety wire is intact.
Changed coolant check to with fill up.
Mooch
ERA Registry Map
If you have an ERA and want to be listed, contact me with your info and I'll put it up. The minimum info I need is chassis number and location. The rest is up to you. The most information needed would be: chassis number, body type, city, name, CC nickname, and email address.
