I think I will chicken out and put the new voltage gauge to the right of the three existing gauges, between the last gauge and the glove box. I will have easier access by opening the glove box door, as CR saw fit to not put in an actual glove box. VDO only makes 4 gauges that size plus a clock. I wish I could get a VDO
oil temperature gauge but no luck. Dosen't the Cobra with the most gauges always win the "peoples choice" car show trophy?
Based on DV's post I am going to mark a circle on the dash a little smaller than the gauge, then with razor cut an X inside the circle and peel back the vinyl to cut the hole. Then file it out to fit the gauge. I hope it is wood as I have not checked.
Jim
