I agree, that far out will likely be too rich, but the point is to see if its a mixture issue. One thing to note....your plugs are going to look like the carb is way rich if all you are doing is running up the street and back on these short test drives. You gotta get out and spin some RPMs for a while and build soem heat before you can get a good plug reading.
